Changing the web interface language
The language of Keenetic devices' Interfaccia web can be changed. English, German, Italian, and other interface languages are available for users. English is a mandatory system component. Besides English, two additional languages can be set for the web interface.
KeeneticOS has a group of language packs, each a separate system component. To add Spanish to the web interface, for example, you need to install the corresponding component in the router.
Here is an example of installing Spanish for the web interface.
Go to the General System Settings menu and click Component options.
Tick the Español language component for installation and click Update KeeneticOS.
The router will install the Spanish language component and automatically reboot. Wait for the device to boot up. After these actions, the web interface will be available in English and Spanish. On the Web Interface Login authentication page, select the language you wish to use in the web interface.
You can also switch the language in the router web interface by clicking on the settings-button.png symbol in the upper right corner of the screen and selecting the required interface language in the Select language field.
