Connecting a USB Ethernet adapter
Models with a USB port support the connection of a compatible USB Ethernet adapter (sold separately). If there are not enough free network ports, you can add an additional LAN port in this way.
To support USB Ethernet adapters, two components must be installed in the router:
1. CDC Ethernet interface for 5G/4G/3G USB modems (mandatory, parent component)
2. USB Ethernet adapters (dependent component)
Notice
The USB Ethernet adapters component supports the connection of adapters with the following chipsets:
ASIX 8817X
Realtek RTL8150/51/52/53/56
Davicom DM9601/9620
We recommend using Realtek 8152/53/56-based adapters as they are the most versatile.
Once you have installed the necessary components, connect the adapter to a USB port on your router.
The router will automatically detect the connected device and, depending on the model and chipset used, add information about the interface to the configuration (in the startup-config.txt file). For example:
interface RealtekEthernet0
description "Realtek USB Ethernet"
usb device-id 0bda 1a56
security-level public
ip address dhcp
ip dhcp client dns-routes
ip dhcp client name-servers
upinterface CdcEthernet0
description "RTL USB-LAN"
usb device-id 1a86 e396
ip address dhcp
upinterface AsixEthernet0
description "USB_Ethernet"
usb device-id 0b95 1790
ip address dhcp
upYou can display the current router configuration in the command-line interface (CLI) using the show ru command.
To display a list of all interfaces, enter the show interface command, then press the Space and Tab keys on your keyboard in sequence.
Once you have verified that the interface has been created, you need to combine it with the LAN network ports into a single segment (by default, this is Bridge0). To do this, execute the respective commands. For example:
interface Bridge0 include RealtekEthernet0 system configuration save
interface Bridge0 include CdcEthernet0 system configuration save
interface Bridge0 include AsixEthernet0 system configuration save
Now connect the network device to the USB Ethernet adapter with a patch cord. Ensure that the device has automatically obtained an IP address from the router and has Internet access.
Support for this feature is optional. Ethernet adapters with a USB interface can only be configured through the router's command-line interface (CLI). The router's web interface will not display any information about the connected USB Ethernet adapter. For a device connected via this adapter, the Client Lists will not display information about the connection speed or port number.
A slight decrease in the maximum speed from that specified in the adapter's specifications is possible, as traffic passing through the USB Ethernet adapter will not have hardware acceleration from the router, and traffic processing in this case will be software-based.
Discussion of the router's operation with USB Ethernet adapters is available on the forum at forum.keenetic.com. All comments, suggestions, and questions should be posted in Community Support & Knowledge Exchange.
