Kullanım Kılavuzu
LED yönetimi
Keenetic cihazlarda LED gösterge kontrol seçeneği bulunmaktadır. Cihaz üzerinde bulunan tüm LED’leri kapatabilirsiniz. Dilerseniz LED’leri belirlenen sürelerde (örneğin gece boyunca kapalı kalmasını istiyorsanız) kapatmayı da seçebilirsiniz.
You can control the LEDs using the device web interface, the command-line interface (CLI), or a button on the case.
  1. The web interface, on the 'General System Settings' page, in the 'LED Indicators' section, provides the settings for controlling the LEDs located on the case of the device (this feature has been added in KeeneticOS 3.6).
    The following values are available for the 'Illumination mode' parameter:
    • Enabled
    • Disabled front
    • Disabled back
    • All LEDs disabled
    If necessary, you can set the LEDs (indicators) to turn off according to the specified time. To do this, refer to the 'Disabling all LEDs on schedule' manual.
  2. Yönetim’ sayfasında bulunan ‘Sistem Ayarları’ Keenetic butonları ve göstergelerinin fonksiyonları’ bölümünden, ‘Göstergeler – LED açık/kapalı’ fonksiyonunu Wi-Fi veya FN butonuna atayabilirsiniz.
    The first time the button is pressed, only the LEDs on the front panel are turned off.
    The second time only the LEDs on the back panel.
    The third time all the LEDs are turned off.
    The fourth time all the LEDs are turned back on, i.e. the state when all the LEDs are lit.
    After restarting the device, the light indication is restored to the factory preset when all the indicators are lit.
  3. The following commands can be used to disable the indicators via the router's command-line interface (CLI):
    system led shutdown front — indicators on the front panel
    system led shutdown back — indicators on the back
    system led shutdown all — all indicators
    This command is used to turn on the LEDs:
    system no led shutdown
    If you execute the command to save the settings, the LEDs will remain disabled even after rebooting.
  4. Göstergeleri belirli bir sürede kapatmak üzere konfigürasyon yapmak için, 'Zaman Takvimi ile Led Göster Işıklarının Yönetimi göstergeleri zamanlı olarak devre dışı bırakma' başlıklı yazıya bakınız.
    A detailed description of commands and their syntax can be found in the command interface reference guide from the İndirme Merkezi.
Destek ekibimizle irtibata geçeceğiniz zaman, ışık göstergelerini devre dışı bıraktığını belirtmeyi unutmayın, aksi takdirde cihazınızın düzgün çalışıp çalışmadığı tespit edilemeyebilir.
