Quick Start Guide
What’s in the Box
  • 1 Keenetic PoE+ Adapter;
  • 1 power cord;
  • 1 multilingual Quick Start Guide.
Connection (Fig. A)
  1. Connect your Keenetic PoE+ Adapter (hereinafter ‘adapter’) to the power source. Check that Power LED C is illuminated.
  2. Connect LAN Network Port to an upstream router or switch with an Ethernet cable (not included in the package).
  3. Connect PoE Network Port to a powered device, such as a Wi-Fi access point, IP phone or IP camera. Check that PoE LED O is illuminated. The quality and length of the Ethernet cabling may affect the power received and the data rate. Use Cat.5e or better Ethernet cables.
Details (Fig. B)
  1. PoE LED O
    Solid green — The adapter is supplying power to a connected device.
    Off — No 802.3af/at-compliant device is connected.
  2. PoE Network Port
    This 10/100/1000 Mbps port provides power and data to an 802.3af/at-compliant device. The power consumption of the connected device must not exceed 30 W.
  3. LAN Network Port
    This 10/100/1000 Mbps port is for connecting to an upstream switch or router.
  4. Power LED C
    Solid green — The adapter is operating properly.
    Off — The adapter is not connected to the power supply.
  5. Power Connector
    For connecting the adapter to a 100–240 V 50/60 Hz mains using the supplied power cord.
Support
For technical support or other information, please visit https://support.keenetic.com/.
Operating Environment
  • Operating temperature range: 0 to +40°C;
  • Operating humidity: 20 to 90% non-condensing;
  • Storage temperature range: –30 to +70°C;
  • Storage humidity: 10 to 90% non-condensing.
Safety
Your adapter is ONLY for indoor use — NEVER use it outdoors. Never use the adapter in an enclosed space, and ensure that it is easily accessible. Stop using any damaged adapter IMMEDIATELY. The adapter contains no user serviceable parts — DO NOT OPEN. Keep the adapter away from water, excessive humidity or heat, and direct sunlight.
Warranty
Certification
Keenetic Limited hereby declares that this adapter is in compliance with all relevant provisions of Directives 2014/35/EU, 2014/30/EU, 2009/125/ EC and 2011/65/EU. See keenetic.com for details of the original EU declaration. According to EC regulation 1275/2008, the power consumption in standby mode is 0.6 W.
Disposal
Do not dispose of your adapter, including power adapter and cables, with your other household waste. Contact your local authority for disposal information.
