Method 1
on the device you are connecting to is illuminated and not blinking.Open a web browser, go to my.keenetic.net, log in to the Main Router's web interface. Open the Mesh Wi-Fi System page and click Acquire to add the Extender to your Wi-Fi System.
on the Extender will illuminate.Nota
Method 2
On the Extender, push the
(Wi-Fi Control) button once to start a fast WPS connection to the wireless network of the main router.Importante
In the same way, push the
button on the Main Router.Nota
If you use a dual-band Keenetic model Buddy 5 (KN-3311) as an Extender, push the Wi-Fi button twice to connect to a 5 GHz wireless network. In the same way, push the button twice on the Main Router. If you push the Wi-Fi Control button once, you'll be connected to a 2.4 GHz Wi-Fi network, but when Extender captured in a Mesh Wi-Fi System, the wireless connection between routers will only work in the 5 GHz band (currently a limitation of the Wi-Fi System design).
