KeeneticOS allows you to add a description (name) for Ethernet ports, which will be displayed on the main screen of the router's web interface in the System Dashboard page's Network Ports section..
You can add a description via the router's web interface starting with KeeneticOS 4.3, and via the command-line interface (CLI) starting with KeeneticOS 3.6.
In the router's web interface, go to the General System Settings page. In the Network Ports section, in the Name field, add a short description or port name (for example, you can specify the network client connected to the port).
For example:
The name you added will appear in the router's web interface under the port icons in the Network Ports section on the System Dashboard page.
Tip
We recommend using a short port name (up to eight characters) so that it displays correctly under the icons. A long name will be split across several lines.
You can also do the same setup from the router's command-line interface (CLI) using the command:
interface {port_number} description {name}For example:
(config)>interface 0 description WAN-ISPNetwork::Interface::Base: "GigabitEthernet1/0": description saved. (config)>interface 1 description TVNetwork::Interface::Base: "GigabitEthernet0/0": description saved. (config)>interface 2 description PCNetwork::Interface::Base: "GigabitEthernet0/1": description saved. (config)>interface 3 description NASNetwork::Interface::Base: "GigabitEthernet0/2": description saved. (config)>system configuration saveCore::System::StartupConfig: Saving (cli).
