Keenetic routers can operate in the main Router Mode and in an additional preset mode, where they connect to the Main Router to expand an existing Wi-Fi network.
Extender Mode combines all the previously used modes — Repeater, Access Point, Adapter.
The term 'Extender' refers to a Keenetic router in the universal mode 'Repeater + Access Point' added to a Wi-Fi System.
Depending on the connection (via cable or Wi-Fi), Keenetic will automatically detect the required mode. If the Extender is connected to the Main Router via an Ethernet cable, the Access Point Mode is used, if the Extender is connected via Wi-Fi — Repeater Mode.
There is a different procedure for switching to additional operating modes on different models.
Some models of Keenetic routers are equipped with a physical mode switch on the case.
There is no possibility to change the operating mode in the web interface for models with a physical mode switch on the case. The mode can only be selected on these models using the mode switch.
On models with a 2-position operating mode switch, set it to position 'B'. The switch is located on the side panel of the router.
In other models, the operating modes are selected in the web interface on the 'General System Settings' page. Click on 'Change operating mode'.
In the actual Keenetic models, only one additional mode is available on the 'Change Operating Mode' page. But once again, please note that Extender Mode combines all the additional modes — Repeater, Access Point, Adapter. You can connect Keenetic to the Main Router via a Wi-Fi network and Ethernet cable in this mode.
To change the mode on the 'Change Operating Mode' page, select the required mode and click 'Save'.
Then you will see a window warning you about switching the router's operation mode. Click 'Confirm'.
Then you will see the mode switching progress bar and an information message about connecting the router to your home network and connecting to its web interface after the mode change.
The current operating mode of a device can be checked on the page 'General System Settings' in the 'Change Operating Mode' section.
Basic points for all operating modes:
For a Keenetic device to work correctly in any additional operating mode, a DHCP server must be running on the Main Router.
A Keenetic device in Adapter and Repeater/Extender Mode should be located in the Wi-Fi coverage area of the Main Router.
You can access the web interface of a Keenetic device in an additional mode by using an IP address obtained in the home network via DHCP. This address will be assigned by the Main Router when connected to the home network and shown in its web interface. If the router in an additional mode is not connected to your home network, to access it, you should use the temporary IP address
192.168.1.3, previously manually assigned an IP address from the range between192.168.1.4and192.168.1.254on your network device (computer, tablet, smartphone).In additional modes, the Keenetic web interface menu will be truncated compared to the main Router Mode (menu items that are not used in additional mode will be unavailable).
USB applications (connection of external drives, printers, Media Server, Download Station, etc.) are available in all additional modes. In additional modes, the router becomes a Layer 2 switch and only USB applications can work on it. For VPN server operation, NAT and routing between server clients and local network segments are required, which is absent in additional modes. Operation of USB modems in additional modes is also not supported.
A Keenetic router uses an independent startup-config file in each operating mode (Router and Extender). When changing the mode, the device is loaded from the configuration file of the corresponding mode, i.e. on those settings that were saved the previous time, instead of resetting to the default settings. For example, if you have set up the main Router Mode, moved to Extender Mode, and then returned to Router Mode, your Router Mode configuration will be fully available because the startup-config file of this mode is saved and loaded.
Tip
If you have activated an additional mode on your device and cannot access its web interface, please refer to the following article: 'Accessing the web interface of a Keenetic operating in one of the additional modes'.
To switch the Keenetic to the default operating mode (Router), proceed as follows:
for models without a hardware switch on the case: go to the web interface, open the 'General System Settings' page, click 'Change operating mode', select 'Router Mode', and click 'Save'.
for models equipped with a hardware mode switch: set the switch to
position A.
You can also click the 'Reset all settings' button on the 'General System Settings' page. Set it to the A position if your router has a mode switch on the case.
Another way to get the Keenetic back to the main mode is to perform a factory reset using the Reset button on the device. In this case, the Keenetic will return to the main mode with the default settings, and all configurations of other modes will also be reset to the factory settings.
