Download Center
There is no need to download firmware files for your Keenetic router. If you already run Keenetic connected to the Internet, upgrading to the latest version of the operating system can be done automatically by enabling Automatic software updates in the General Settings menu. In this case, you don't have to lift a finger to be sure that your Keenetic is always up to date and secure. The operating system will update itself accordingly, even if you have a custom set of components and applications installed. The manual upgrade is also possible by clicking on Install the update in the General Settings menu of the Web Interface.
How to use the KeeneticOS file can to read in the article 'Updating KeeneticOS by a system file'.
Datasheets, User Guides, Reference Materials
This guide covers initial setup and essential recommendations for home users.
Quick Start Guide (EN) (Multilingual) for Keenetic Orbiter Pro (KN-2810 EU).
Covers the Command-Line Interface (CLI), which allows configuration of your Keenetic router using text commands. This guide provides a complete listing of all possible commands, information on the relationships between the commands, and a background on how to use them. The Command-Line Interface is a preferred tool for advanced users, as it provides a more concise and compelling means to control your Keenetic router.
Command Reference Guide for Keenetic Orbiter Pro (KN-2810 EU).
Recovery Utility for Keenetic Orbiter Pro (KN-2810 EU).
Before using the utility, be sure to read the article KeeneticOS recovery. Required OS: Windows XP/7/8/10/11.
