KeeneticOS 3.8
Highlights at a glance
Welcome to KeeneticOS release 3.8! This release introduces completely reworked Internet safety provisions, improved traffic classification and prioritization, and multiple other performance improvements and fixes:
Block annoying ads and trackers, protect your privacy, defend against security threats and enforce clean Internet access for children with the new Cloud-based content filtering and ad blocking component — the new filter combines seven popular public DNS resolvers into one configuration, allowing you to mix filtering profiles from different service providers to your devices in one setup. Supported public DNS resolvers include AdGuard DNS, CleanBrowsing, Cloudflare DNS, Neustar UltraDNS Public, OpenDNS, Quad9, and Yandex.DNS.
Add custom DNS profiles for even greater flexibility when public DNS presets are not enough.
Assign default filtering profiles to network segments.
Get complete peace of mind with the new NextDNS integration. NextDNS protects you from all kinds of security threats, blocks ads and trackers on websites and inside apps and provides a safe and supervised Internet for kids.
The traffic classification engine now detects and prioritizes various types of traffic inside a single app independently — for example, a video call and a file transfer via the same messenger app will have different traffic priorities according to your IntelliQoS rules.
New inbound and outbound bandwidth control options are now available for Internet connection policies to further improve traffic prioritization and minimize "buffer bloat."
The Mesh Wi-Fi system initialization on startup now happens considerably faster.
The Mesh Wi-Fi system’s new Conditional Wi-Fi broadcast option prevents the connection of wireless clients to the non-operatable extender, which loses connection to the controller.
Behind the scenes, not visible in the generic version, we have also developed a feature set for regional ISPs, covering initial device provisioning and centralized monitoring and management. Drop us a mail at support@keenetic.desupporto@keenetic.it if you are interested.
As always, if you have any feedback (or want to say hi
), drop us a line in the forum. To learn more about Keenetic, visit the Help Center.
KeeneticOS 3.8.5.4
27/10/2022
Fixed
Fixed an error in the Keenetic Mobile Application component that was causing the Web Interface to respond slowly or become unresponsive. [SYS-662]
KeeneticOS 3.8.5
07/09/2022
Improved
Backward compatibility with the
Europe/Kievtime zone was added after it was renamed toEurope/Kyiv. See Release 2022b - 2022-08-10 notes. [NDM-2362]
Fixed
The device schedule assignment is now applying as expected. [NWI-1306]
The subnet mask validator now acts appropriately with the
255.255.255.255 (/32)network mask. [NWI-1310]Fixed Fast transition (FT) compatibility with the Samsung Galaxy A52 smartphone. [SYS-608]
The positioning of tooltips and tables in the Web Interface has been changed to provide a better view on screens with
1366x768resolution. [NWI-1365]
KeeneticOS 3.8.4
15/08/2022
Improved
The
source IP addressis appended to the HTTP/HTTPS serverauthentication failuremessage, providing advanced network maintenance information. The logging of failed authentication to the Web Interface is disabled by default. Use the following CLI command to enable:ip http log auth[NDM-2317][E] Jul 25 16:16:30 ndm: Core::Scgi::Auth: authentication failed for user "admin" from "92.162.143.77".
Fixed
Renaming an Extender no longer causes unnecessary reconfiguration of the Wi-Fi System. [NWI-1188]
The empty Traffic Monitor page has been fixed. [NWI-1290]
The Enter button acts as the Next string action instead of the Save action during editing of the OpenVPN connection. [NWI-1286]
The legend captions for the Spectrum analyser and Wi-Fi monitor have been corrected. [NWI-1285]
Fixed the font size of the IPsec VPN input fields in the Safari browser. [NWI-1287]
Restored DNS over TLS (DoT) operation with custom Domain setting. [NDM-2286]
Reissuing the KeenDNS certificate no longer causes the
ndm:Acme::Client: unable to use account keyerror message under certain conditions. [NDM-2351]
KeeneticOS 3.8.3
18/07/2022
Fixed
Corrected the Address pool size calculation for the DHCP server of the Segment settings. [NWI-1119]
Fixed the TLS domain name and Domain fields mixing up in DNS configuration settings under certain conditions. [NWI-1222]
Adding a custom DNS server no longer requires a double saving action in the Web Interface. [NWI-1223]
Restored the Speed limit saving for unregistered devices in the Device lists menu. [NWI-1239]
The message telling that the ISP is managing the Keenetic device appeared in the wrong context under certain conditions. [NWI-1246]
Keenetic mobile application no longer sends the alert about an empty administrator password after the initial setup. [SYS-583]
KeeneticOS 3.8.2
27/06/2022
New
Extended flexibility with a secure DNS setup: Resolve specified domain names via a preset secure DNS server with the following CLI commands for DoT (DNS over TLS) and DoH (DNS over HTTPS) options. [NDM-2040]
dns-proxy tls upstream {address} [port] [sni {sni}] [spki {spki}] [on {interface}] [domain {domain}]dns-proxy https upstream {url} {json | dnsm} [spki {spki}] [on {interface}] [domain {domain}]
nextdns check-availability;nextdns authenticate {login} {password} [{pin}]— please register with NextDNS before authentication;show nextdns profiles— look for the token associated with the filtering profile and apply it with the following command;nextdns assign ( ({host} {token}) | (interface {iface} {token}) | {token} );dns-proxy filter engine nextdns— to enable NextDNS.
no ntce memory-watcherCLI command to disable the memory "pressure watcher" mechanism enabled by default. [NDM-1995]More content filtering and ad blocking choices with outstanding flexibility: AdGuard DNS, CleanBrowsing, Cloudflare DNS, Neustar UltraDNS Public, OpenDNS, Quad9, Yandex.DNS are now available at once with the redesigned Public DNS resolvers & custom DNS profiles option. Mix and match content filtering services with registered devices for complete control. Install the all-new Cloud-based Content Filtering and Ad Blocking system component of KeeneticOS and give it a try. [NDM-1820, SYS-361, NWI-784]
Warning
mws member {member} reboot. [NDM-1946]
Improved
1.1.1o, fixing the CVE-2022-1292 and CVE-2022-1473 vulnerabilities. [SYS-551]
Added
MTUcontrol to IKEv2 VPN client configuration in the advanced settings section, providing better interoperability with certain VPN providers, for example, Surfshark VPN. [NWI-974]
Added a warning message while setting up a Port forwarding rule for the HTTPS or 443/TCP protocol. [NWI-977]
196characters for IPsec VPN and IPsec/L2TP connections, providing proper connection to corporate networks with firm security policies. [NDM-2128]Added the display of the
regional codenext to the Model name field on the About the system tile. [NWI-1027]Improved IPv4 availability criteria for
MAP-T-enabled connections for the proper display on the Dashboard page. [NWI-1025]Added links to the NextDNS account configurations on the Internet safety page, providing easy access to the NextDNS management portal. [NWI-1020]
Updated the metadata file of the Web Interface to comply with the Progressive Web App (PWA) specification. [NWI-904]
Enabled offloading of the Top — Traffic priority via the hardware
PPE(Packet Processing Engine). [SYS-506]We replaced Service Class with a Traffic Priority setting for registered devices and IntelliQoS. [NWI-939]
New configuration option for devices in the Extender mode: a network Segment can have No IP address. [NWI-847]
The controls of the User-defined routes section are moved to the top, providing easy management, with a long list of the routes. [NWI-862]
Fixed
-' symbol is prohibited at the KeenDNS domain's beginning and end. [NWI-1159]Fixed the bug preventing Extender from re-establishing the wireless backhaul link after a Controller restart under certain conditions. [SYS-570]
After deactivation, the Wi-Fi network's Fast Transition (802.11r) feature remained advertised due to misconfiguration, leading to connection errors. [SYS-574]
Fixed the Hardware network accelerator toggle visibility depending on installed KeeneticOS system component. [NWI-1146]
VLAN ID is busyerror message on the device in the Extender mode. [NDM-2252]
Updated and unified toggle behaviour for the Application section. [NWI-1037]
Internet Checker probe requests are suppressed until consent to the Device Privacy Notice is given. [NDM-2201]
KeeneticOS time synchronization via the NTP protocol is postponed until consent to the Device Privacy Notice is secured. [NDM-2217]
Fixed the reason for the
fastvpnservice operation causing the following messagesfastvpn: len = 56, head = ...in the System log. [SYS-557]
Wi-Fi radio turned off by the Wi-Fi button now keeps this state after a system reboot or power-off event. [SYS-78]
Swapping WAN and LAN ports now operates properly. This swapping helps if a customer needs the PoE (Power over Ethernet) feature on the LAN port. [SYS-529]
1:1 IPv4sharing ratio option. [NDM-2127]
Fixed the selection of an optimal backhaul connection to the Mesh Wi-Fi System node based on Wi‑Fi RSSI and STP distance metrics. [SYS-486]
Fixed the
invalid domain nameerror messages for the DHCP server with an enabledupdate-dnsoption upon receiving DHCP requests with special symbols in thehostnamefield. [NDM-2085]Fixed invalid remote RADIUS server requests with WPA2 Enterprise network protection. [NDM-2081]
The menu list of the Web Interface now displays with full height on the mobile Safari® browser. [NWI-914]
The Port Forwarding page now displays correctly on mobile screens. [NWI-883]
The sorting of the User-defined routes table now functions appropriately. [NWI-873]
The Wi-Fi beacon frames broadcasted during the auto-channel selection (ACS) routine had invalid channel numbers. [SYS-473]
ndm: Hotspot::Account: data is absent for host "aa:bb:cc:dd:ee:ff"error messages for devices that have been offline since system restart. [NDM-2057]
ip hotspot auto-scan no interface Homenow operates correctly when the corresponding Segment uses a wide IP subnet mask255.255.240.0. [NDM-1940]
Fixed
ntce: unknown protocol.error message in the System log of the Traffic classification engine component triggered by IPv6/Teredo packets. [NDM-2044]Fixed an
Invalid username or passworderror displaying on the Web Interface Login page under certain conditions. [NWI-805]Fixed hint layout and uptime label on dashboard tiles for mobile screens. [NWI-832]
Corrected Network access naming for VPN server settings. [NWI-838]
Fixed the display of Connection statistics for
port 0when it operates as a part of the LAN network instead of the default WAN operation. [NDM-779]
