KeeneticOS 3.7
Highlights at a glance
Release 3.7 is jam-packed with new features, fixes and improvements. These highlights are only the beginning:
See which applications run on your network. The new Traffic Classification Engine detects thousands of applications in real-time and displays them for you in the Traffic monitor and Application traffic analyzer.
Manage all your networks in one convenient Web Portal. The new Keenetic RMM system (now in beta) is a cloud-based multi-site remote monitoring and management solution purpose-built for Small/Medium-sized businesses to help keep critical networks and infrastructure online 24/7. Visit rmm.keenetic.com to learn more.
Enjoy multiple KeenDNS improvements, including automatic operating mode selection, the ability to password-protect remote access to the web applications, easy remote access configuration to attached 4G/3G USB modem dongles, and support for IP/FQDN web application targets.
Customize the Web interface title and header for ease of navigation between multiple Keenetic devices.
Set up IP-encapsulated tunnels (IPIP, GRE, EoIP) easily with the new configuration screen.
Build a customized KeeneticOS image with your services and scripts using the Keenetic Software Development Kit (SDK) available on GitHub.
Learn more about the latest developments at the new device-tailored multilingual documentation portal.
As always, if you have any feedback (or want to say hi
), drop us a line in the forum. To learn more about Keenetic, visit the Help Center.
KeeneticOS 3.7.4
31/03/2022
Improved
Fixed
KeeneticOS 3.7.3
24/02/2022
Improved
We plan to add a user-defined setting for Wi‑Fi System Extenders to stop broadcasting Wi‑Fi networks if the backhaul connection to the Wi‑Fi System Controller is lost. Meanwhile, the new behaviour introduced in KeeneticOS 3.7 Beta 1 is temporarily disabled to prevent issues with specific Wi-Fi System configurations in the field. [NDM-2068]
Fixed
The Speed limit setting for a host no longer causes the system to reboot under certain conditions. [SYS-375]
The 5GHz Wi‑Fi SSID's
beaconsbroadcasting now operates correctly with the multiple Segments configuration. [SYS-489]The Band Steering algorithm has improved signal level measuring to prevent early swapping of wireless clients between 2.4 and 5 GHz bands. [SYS-379]
startup-configfile size of more than 64 Kbytes. [NDM-2090]The Wireless ISP connection can now link correctly to a third-party Wi-Fi network with an active
backhaulsupport bit. [SYS-479]The Wireless ISP tile for 5 GHz connection on the Dashboard menu now links to the proper path, Wireless ISP > WISP 5GHz. [NWI-872]
KeeneticOS 3.7.2
27/01/2022
New
hold-downtimer. If the Wi‑Fi Access Point with WPA-PSK + WPA2-PSK protection mode detects twoMIC errors in RXfailures within 60 seconds, it blocks all the wireless TKIP clients on that interface for the hold-down timer. Use this command to disable or tune this behaviour. [SYS-434]interface {name} encryption tkip hold-down {hold-down}— set thehold-downtimer in seconds (from 0 to 60). The default value is 60 sec.
Improved
Improved compatibility of the 2.4 GHz Wireless ISP (WISP) connection with the Wi‑Fi hotspot of the Realme 3 and other MediaTek-based smartphones. [SYS-383]
Fixed
The LED power shutdown control now operates correctly with Keenetic devices having a single-LED indicator. [SYS-422]
ndm: Http::Nginx: there are errors in config, reconfigure.ndm: Http::Manager: unable to update configuration, retry.
KeeneticOS 3.7.1
14/12/2021
New
ntce qos priority {category} {priority}— assign certain priority for certain categoriesntce qos enable— enable QoS processing for thentce(network traffic classification engine)
service ntceCLI command. The component operates autonomously and does not depend on any external services. [NDM-1476, NDW-2109]
The KeeneticOS build system is now available on GitHub. You can use the Keenetic Software Development Kit (SDK) to build a customized Keenetic firmware image with your own services and scripts. [NDM-1398]
Improved
Called-Station-Idmessage —'50-FF-20-AA-BB-CC:Keenetic-5555'. [SYS-9]
Implemented
/storagepartition formatting on factory reset, providing secure clearance of the private user's information or installed OPKG image. [NDM-1943]
Resolver prefix doesn't appear to contain a hostname. [NDM-1938]Enabled centralized Wi‑Fi
country codeconfiguration from Wi‑Fi system Controller, and blocked this setting on Extenders. [NDM-1921, NWI-733]Improved operability of the Wi‑Fi connection in a noisy environment. [SYS-398]
Implemented brute-force protection for remote access to the device via the KeenDNS domain name in the Cloud access mode. [NDM-1804]
*.keenetic.iodomain. Security tokens and automatically installed SSL certificates ensure safe and secure operation. [NDM-1287, NWI-323]Added the Optimization mode selector to the IPsec VPN server application settings. It changes the set of supported encryption algorithms, as follows. [NDM-1259, NWI-327]
DESand3DES;Legacy — enables both
DESand3DESfor compatibility with legacy clients;Performance — enables modern encryption algorithm
CHACHA20-POLY1305only, for faster and secure data exchange with supported peers.
Added new IntelliQoS priority configuration page in the Web Interface. It ensures inbound, and outbound, bandwidth for prioritized applications and tasks via pre-defined, drag-and-drop category group presets. [NDW-2413]
ICMP - Host unreachablereplaces theDROPaction for the internal firewall rule of KeeneticOS when the user's device is accessing a blocked DNS over HTTPS (DoH) / DNS over TLS (DoT) DNS server. This change helps to speed up fallback to allowed DoT/DoH DNS servers on the Keenetic device. [NDM-1470]It is now possible to use
%and^characters in the Username field of a DDNS profile. [NDM-1255]
The firmware image build with the Keenetic SDK is now compatible with the Keenetic Recovery Utility for Windows OS. You can use this utility to upload a firmware image to your Keenetic device. [NDM-1530]
Implemented a new smart queue management algorithm — NDM Fast Queue (NFQ). NFQ is CAKE-based, and optimized for speeds above 24 Mbit/s. When you limit the Internet connection speed for a host or network segment at a rate above 24 Mbit/s, the NFQ algorithm performs shaping. For rates below 24 Mbit/s, the CAKE algorithm does the job. [NDM-1247]
0.0.0.0/0. [NDM-1222]The CLI command for adjusting the TTL value of incoming IP packets has a new syntax: [NDM-1419]
interface ip adjust-ttl (set | inc | dec)— old syntax, obsolete now;interface ip adjust-ttl recv {recv}— new syntax.
Fixed
1.1.1.1:5353. [NWI-766]Fixed the forced disconnect of live Wi‑Fi clients when removing them from the Whitelist of the Wireless ACL. [SYS-400]
no buffer space availableerror message in the System log. [NDM-1913]
unable to reset loop detectorerrors in Extender logs. [NDM-1658]Fixed the reason for the
Rtx::Iapp: unsupported interfaceerrors in Extender logs. [NDM-1753]
Removed the password prompt flick when navigating from the Mesh Wi‑Fi System page of a Controller to connected Extenders. [NDM-1724]
https-dns-proxy: Error binding. [NDM-541]
Cleanup of obsolete TCP (Transmission Control Protocol) and UDP (User Datagram Protocol) sessions of the Traffic classification engine system component, which caused excessive memory consumption. [NDM-1496]
The detection of SIP (Session Initiation Protocol), RTP (Real-time Transport Protocol), and RTCP (RTP Control Protocol) protocols by the Traffic classification engine system component. [NDM-1576]
Devices in Extender mode used to crash under certain circumstances. [NDM-1546]
KeeneticOS 3.7 Beta 2
This is the initial shipping release for Keenetic Orbiter Pro (KN-2810).
