KeeneticOS 3.8
What’s new?
New content filtering and ad-blocking options:
Choose filtering profiles from popular public DNS resolvers: AdGuard DNS, CleanBrowsing, Cloudflare DNS, Neustar UltraDNS Public, OpenDNS, Quad9, Yandex.DNS;
Mix and match filtering profiles from different service providers to your devices in one setup;
Add your custom DNS profiles and use them along with public DNS resolvers;
Assign default filtering profiles to network segments;
Try content filtering services from the NextDNS.
KeeneticOS 3.8.5
02/09/2022
Improved
Backward compatibility with the
Europe/Kievtime zone was added after it was renamed toEurope/Kyiv. See Release 2022b - 2022-08-10 notes. [NDM-2362]
Fixed
The device schedule assignment is now applying as expected. [NWI-1306]
The subnet mask validator now acts appropriately with the
255.255.255.255 (/32)network mask. [NWI-1310]Fixed Fast transition (FT) compatibility with the Samsung Galaxy A52 smartphone. [SYS-608]
The positioning of tooltips and tables in the Web Interface has been changed to provide a better view on screens with
1366x768resolution. [NWI-1365]
KeeneticOS 3.8.4
12/08/2022
Improved
The
source IP addressis appended to the HTTP/HTTPS serverauthentication failuremessage, providing advanced network maintenance information. The logging of failed authentication to the Web Interface is disabled by default. Use the following CLI command to enable:ip http log auth[NDM-2317][E] Jul 25 16:16:30 ndm: Core::Scgi::Auth: authentication failed for user "admin" from "92.162.143.77".
Fixed
Renaming an Extender no longer causes unnecessary reconfiguration of the Wi-Fi System. [NWI-1188]
The empty Traffic Monitor page has been fixed. [NWI-1290]
The Enter button acts as the Next string action instead of the Save action during editing of the OpenVPN connection. [NWI-1286]
The legend captions for the Spectrum analyser and Wi-Fi monitor have been corrected. [NWI-1285]
Fixed the font size of the IPsec VPN input fields in the Safari browser. [NWI-1287]
Restored DNS over TLS (DoT) operation with custom Domain setting. [NDM-2286]
KeeneticOS 3.8.3
12/07/2022
Fixed
Corrected the Address pool size calculation for the DHCP server of the Segment settings. [NWI-1119]
Fixed the TLS domain name and Domain fields mixing up in DNS configuration settings under certain conditions. [NWI-1222]
Adding a custom DNS server no longer requires a double saving action in the Web Interface. [NWI-1223]
Restored the Speed limit saving for unregistered devices in the Device lists menu. [NWI-1239]
The message telling that the ISP is managing the Keenetic device appeared in the wrong context under certain conditions. [NWI-1246]
Keenetic mobile application no longer sends the alert about an empty administrator password after the initial setup. [SYS-583]
KeeneticOS 3.8.2
22/06/2022
Fixed
Fixed the issue with the Safari browser which was resulting in a blank Web Interface Login page. [NWI-1216]
KeeneticOS 3.8.1
20/06/2022
Improved
Fixed
-' symbol is prohibited at the KeenDNS domain's beginning and end. [NWI-1159]Fixed the bug preventing Extender from re-establishing the wireless backhaul link after a Controller restart under certain conditions. [SYS-570]
After deactivation, the Wi-Fi network's Fast Transition (802.11r) feature remained advertised due to misconfiguration, leading to connection errors. [SYS-574]
KeeneticOS 3.8.0
10/06/2022
New
Fixed
Fixed the Hardware network accelerator toggle visibility depending on installed KeeneticOS system component. [NWI-1146]
VLAN ID is busyerror message on the device in the Extender mode. [NDM-2252]
KeeneticOS 3.8 Beta 2
20/05/2022
New
Improved
1.1.1o, fixing the CVE-2022-1292 and CVE-2022-1473 vulnerabilities. [SYS-551]
Fixed
Updated and unified toggle behaviour for the Application section. [NWI-1037]
Internet Checker probe requests are suppressed until consent to the Device Privacy Notice is given. [NDM-2201]
KeeneticOS time synchronization via the NTP protocol is postponed until consent to the Device Privacy Notice is secured. [NDM-2217]
Restored Internet Checker behaviour to support default routes through a gateway in the local network using topologies with a non-Keenetic device as the primary router. [NDM-2220]
Fixed the reason for the
fastvpnservice operation causing the following messagesfastvpn: len = 56, head = ...in the System log. [SYS-557]
KeeneticOS 3.8 Beta 1
21/04/2022
New
Extended flexibility with a secure DNS setup: Resolve specified domain names via a preset secure DNS server with the following CLI commands for DoT (DNS over TLS) and DoH (DNS over HTTPS) options. [NDM-2040]
dns-proxy tls upstream {address} [port] [sni {sni}] [spki {spki}] [on {interface}] [domain {domain}]dns-proxy https upstream {url} {json | dnsm} [spki {spki}] [on {interface}] [domain {domain}]
nextdns check-availability;nextdns authenticate {login} {password} [{pin}]— please register with NextDNS before authentication;show nextdns profiles— look for the token associated with the filtering profile and apply it with the following command;nextdns assign ( ({host} {token}) | (interface {iface} {token}) | {token} );dns-proxy filter engine nextdns— to enable NextDNS.
no ntce memory-watcherCLI command to disable the memory "pressure watcher" mechanism enabled by default. [NDM-1995]More content filtering and ad blocking choices with outstanding flexibility: AdGuard DNS, CleanBrowsing, Cloudflare DNS, Neustar UltraDNS Public, OpenDNS, Quad9, Yandex.DNS are now available at once with the redesigned Public DNS resolvers & custom DNS profiles option. Mix and match content filtering services with registered devices for complete control. Install the all-new Cloud-based Content Filtering and Ad Blocking system component of KeeneticOS and give it a try. [NDM-1820, SYS-361, NWI-784]
Warning
mws member {member} reboot. [NDM-1946]
Improved
Added
MTUcontrol to IKEv2 VPN client configuration in the advanced settings section, providing better interoperability with certain VPN providers, for example, Surfshark VPN. [NWI-974]
Added a warning message while setting up a Port forwarding rule for the HTTPS or 443/TCP protocol. [NWI-977]
196characters for IPsec VPN and IPsec/L2TP connections, providing proper connection to corporate networks with firm security policies. [NDM-2128]Added the display of the
regional codenext to the Model name field on the About the system tile. [NWI-1027]Improved IPv4 availability criteria for
MAP-T-enabled connections for the proper display on the Dashboard page. [NWI-1025]Added links to the NextDNS account configurations on the Internet safety page, providing easy access to the NextDNS management portal. [NWI-1020]
Updated the metadata file of the Web Interface to comply with the Progressive Web App (PWA) specification. [NWI-904]
Enabled offloading of the Top — Traffic priority via the hardware
PPE(Packet Processing Engine). [SYS-506]We replaced Service Class with a Traffic Priority setting for registered devices and IntelliQoS. [NWI-939]
New configuration option for devices in the Extender mode: a network Segment can have No IP address. [NWI-847]
The controls of the User-defined routes section are moved to the top, providing easy management, with a long list of the routes. [NWI-862]
Fixed
Wi-Fi radio turned off by the Wi-Fi button now keeps this state after a system reboot or power-off event. [SYS-78]
Swapping WAN and LAN ports now operates properly. This swapping helps if a customer needs the PoE (Power over Ethernet) feature on the LAN port. [SYS-529]
1:1 IPv4sharing ratio option. [NDM-2127]
Fixed the selection of an optimal backhaul connection to the Mesh Wi-Fi System node based on Wi‑Fi RSSI and STP distance metrics. [SYS-486]
Fixed the
invalid domain nameerror messages for the DHCP server with an enabledupdate-dnsoption upon receiving DHCP requests with special symbols in thehostnamefield. [NDM-2085]Fixed invalid remote RADIUS server requests with WPA2 Enterprise network protection. [NDM-2081]
The menu list of the Web Interface now displays with full height on the mobile Safari® browser. [NWI-914]
The Port Forwarding page now displays correctly on mobile screens. [NWI-883]
The sorting of the User-defined routes table now functions appropriately. [NWI-873]
The Wi-Fi beacon frames broadcasted during the auto-channel selection (ACS) routine had invalid channel numbers. [SYS-473]
ndm: Hotspot::Account: data is absent for host "aa:bb:cc:dd:ee:ff"error messages for devices that have been offline since system restart. [NDM-2057]
ip hotspot auto-scan no interface Homenow operates correctly when the corresponding Segment uses a wide IP subnet mask255.255.240.0. [NDM-1940]
Fixed
ntce: unknown protocol.error message in the System log of the Traffic classification engine component triggered by IPv6/Teredo packets. [NDM-2044]Fixed an
Invalid username or passworderror displaying on the Web Interface Login page under certain conditions. [NWI-805]Fixed hint layout and uptime label on dashboard tiles for mobile screens. [NWI-832]
Corrected Network access naming for VPN server settings. [NWI-838]
Fixed the display of Connection statistics for
port 0when it operates as a part of the LAN network instead of the default WAN operation. [NDM-779]
