KeeneticOS 3.7
KeeneticOS 3.7.4
29/03/2022
Improved
Fixed
KeeneticOS 3.7.3
18/02/2022
Improved
We plan to add a user-defined setting for Wi‑Fi System Extenders to stop broadcasting Wi‑Fi networks if the backhaul connection to the Wi‑Fi System Controller is lost. Meanwhile, the new behaviour introduced in KeeneticOS 3.7 Beta 1 is temporarily disabled to prevent issues with specific Wi-Fi System configurations in the field. [NDM-2068]
Fixed
The Speed limit setting for a host no longer causes the system to reboot under certain conditions. [SYS-375]
The 5GHz Wi‑Fi SSID's
beaconsbroadcasting now operates correctly with the multiple Segments configuration. [SYS-489]The Band Steering algorithm has improved signal level measuring to prevent early swapping of wireless clients between 2.4 and 5 GHz bands. [SYS-379]
startup-configfile size of more than 64 Kbytes. [NDM-2090]The Wireless ISP connection can now link correctly to a third-party Wi-Fi network with an active
backhaulsupport bit. [SYS-479]The Wireless ISP tile for 5 GHz connection on the Dashboard menu now links to the proper path, Wireless ISP > WISP 5GHz. [NWI-872]
KeeneticOS 3.7.2
20/01/2022
New
hold-downtimer. If the Wi‑Fi Access Point with WPA-PSK + WPA2-PSK protection mode detects twoMIC errors in RXfailures within 60 seconds, it blocks all the wireless TKIP clients on that interface for the hold-down timer. Use this command to disable or tune this behaviour. [SYS-434]interface {name} encryption tkip hold-down {hold-down}— set thehold-downtimer in seconds (from 0 to 60). The default value is 60 sec.
Improved
Improved compatibility of the 2.4 GHz Wireless ISP (WISP) connection with the Wi‑Fi hotspot of the Realme 3 and other MediaTek-based smartphones. [SYS-383]
Fixed
The LED power shutdown control now operates correctly with Keenetic devices having a single-LED indicator. [SYS-422]
ndm: Http::Nginx: there are errors in config, reconfigure.ndm: Http::Manager: unable to update configuration, retry.
KeeneticOS 3.7.1
10/12/2021
Improved
Called-Station-Idmessage —'50-FF-20-AA-BB-CC:Keenetic-5555'. [SYS-9]
Fixed
KeeneticOS 3.7.0
28/11/2021
New
There are no changes for Keenetic Orbiter Pro (KN-2810).
Improved
Implemented
/storagepartition formatting on factory reset, providing secure clearance of the private user's information or installed OPKG image. [NDM-1943]There are no changes for Keenetic Orbiter Pro (KN-2810).
Fixed
1.1.1.1:5353. [NWI-766]Fixed the forced disconnect of live Wi‑Fi clients when removing them from the Whitelist of the Wireless ACL. [SYS-400]
KeeneticOS 3.7 Beta 8
21/11/2021
Improved
Fixed
KeeneticOS 3.7 Beta 7
17/11/2021
New
Improved
Resolver prefix doesn't appear to contain a hostname. [NDM-1938]Enabled centralized Wi‑Fi
country codeconfiguration from Wi‑Fi system Controller, and blocked this setting on Extenders. [NDM-1921, NWI-733]Improved operability of the Wi‑Fi connection in a noisy environment. [SYS-398]
Implemented brute-force protection for remote access to the device via the KeenDNS domain name in the Cloud access mode. [NDM-1804]
Fixed
no buffer space availableerror message in the System log. [NDM-1913]
KeeneticOS 3.7 Beta 3
30/09/2021
New
Improved
Fixed
KeeneticOS 3.7 Beta 2
This is the initial shipping release for Keenetic Orbiter Pro (KN-2810).
