Possible reasons for slow LTE connection speeds on a router
Question: Why is the speed slow when connecting a router to a mobile network operator’s network via LTE? What factors determine connection and data transfer speeds on LTE networks?
Answer: LTE speed depends on several factors. The main reasons include: device specifications, signal quality, network condition and capacity, as well as restrictions imposed by the mobile network operator.
In our experience, slow speeds are often due to restrictions imposed by the mobile network operator. Please refer to the information below.
Device capabilities
Keenetic offers a range of models with a built-in 4G modem that support the 4G Cat 12 standard with speeds of up to 600 Mbit/s, 4G Cat 6 with speeds of up to 300 Mbit/s or 4G Cat 4 with speeds of up to 300 Mbit/s. You can find detailed technical specifications for the models in our product catalogue on our website.
Under normal conditions, provided there are no restrictions imposed by the mobile network operator on the device, SIM card, region, or base station, our routers with 4G modems are technically capable of achieving the speeds stated in their technical specifications.
Signal quality
  • The distance to the base station is an important factor that directly affects signal strength. As you move further away from the base station, the strength of the received signal weakens. A weak signal prevents high data transfer speeds from being maintained. Signal quality is affected not only by the distance to the base station, but also by obstacles in the signal’s path — such as buildings, terrain and trees. Indoors, the signal can also be weakened by walls, floors and metal structures.
    It is important to understand that signal strength alone does not determine speed. In some cases, a reduction in speed is possible even with a good signal strength. The main limiting factors are base station congestion and the policies set by the operator.
    Additional information can be found in the article LTE signal quality parameters.
Network status and capabilities
  • Mobile operators’ speed policies
    Mobile operators may impose speed caps based on regional conditions or overall network load to avoid negatively impacting other subscribers and service quality. These limits may vary depending on whether a mobile phone or a router is being used, whether there is a single subscriber or multiple subscribers, the level of base station congestion, and regional network operating conditions.
    In areas with limited base station capacity or high subscriber density, these limits may be automatically reduced during periods of congestion and raised again when network load decreases. As routers with LTE modems typically serve multiple subscribers and generate continuous traffic, mobile operators often impose stricter limits on them than on mobile phones. Otherwise, heavy data usage could affect the performance of core services, such as voice calls.
  • Traffic prioritisation
    In mobile networks, data traffic has a lower priority than voice and video services. Although voice and video calls may work without disruption, data speed test results may be lower and may not fully reflect the actual user experience. For example, a speed test conducted solely for data transmission may show 20 Mbit/s, whilst the actual bandwidth when using voice or video services may reach 30–40 Mbit/s.
  • Frequencies available to the operator
    Modern mobile networks are not usually limited to a single frequency. Operators often use combinations of several frequency bands to increase overall throughput. Carrier Aggregation technology allows a single subscriber to use multiple frequency bands simultaneously (for example, B3+B7 or B7+B40), which significantly increases speed. Carrier aggregation is supported on modems with LTE Category 6 or higher. If carrier aggregation is unavailable or is not functioning, the modem is limited to a single band, and speeds will decrease when that band is congested.
  • Differences between base stations
    If several base stations are available in a particular location (neighbourhood), a mobile phone and a router may connect to different stations during testing, resulting in different speed readings.
  • Base station load
    The resources of a single base station are shared among the subscribers connected to it. Speeds may be reduced in densely built-up urban areas with a large number of subscribers per base station, as well as during peak hours or in crowded places.
  • Use in rural and urban areas
    LTE routers and data SIM cards are widely used in rural areas where fibre-optic or DSL infrastructure is underdeveloped. In some regions, base stations connect to the backbone network via radio links with a total bandwidth of 50–100 Mbit/s, which is shared among many subscribers. Even with good signal quality, achievable speeds may be limited by the bandwidth of the communication channels to the base station. In urban areas, despite higher communication channel bandwidth, high subscriber density can still lead to similar limitations.
Mobile network operator restrictions
  • SIM card restrictions
    Mobile network operators may impose restrictions on SIM card use or apply speed limits. Please ensure that the SIM card supports 4G data transmission and that there are no restrictions on its use in modems or routers.
  • Restrictions related to the tariff plan
    Some mobile operators offer data plans for modems/routers with pre-defined terms of use. For example, once your data allowance has been used up, the operator may reduce your connection speed. Speed and data limits may also depend on the designated region or base station. Using such tariff plans outside the specified area may result in speed restrictions.
Conclusion
If you notice variations in LTE speeds, this is most likely due to the type of SIM card, the structure of your tariff plan, regional usage, base station load or the mobile operator’s policy, rather than the technical capabilities of the device itself. You can compare the results by testing the device in a different location or with a SIM card from another mobile network operator. If, after these tests, you still suspect there is a problem, please contact our support team.
