System dashboard
By connecting to a web interface of a Keenetic router, you will see the starting page System dashboard.
It contains the main information panels (their set depends on the capabilities of the model and a selection of components of the router's built-in operating system) — Internet, My network and Wi-Fi, Applications, Network ports, Mesh Wi-Fi System, Traffic Monitor, Wi-Fi Monitor, About the system.
Internet
On this panel, you can view the Internet connection status, connection session duration, current speeds of traffic reception/transmission, WAN IP address on the external interface of the device, registered KeenDNS domain name, total amount of received and sent data.
The graph shows the current receiving and transmitting speeds for the last 3 minutes. This is not the maximum throughput rate of your internet channel.
If a backup connection is configured, you will also see the status and information about this connection.
My networks and Wi-Fi
This section provides information about the router's network segments. Here you can see the number of clients connected to the router via cable and Wi-Fi.
Click the icon-dash.png icon to display more information about network segments. For example, you can view the set IP address of the network and find out the current Wi-Fi channel number.
You can quickly turn on/off the Wi-Fi network using the switch.
Clicking on the Show connection info button will show information about this Wi-Fi network, including the password and QR code that will allow you to connect. You will be able to copy the password, print out the information and run WPS. For example:
USB drives and printers
This panel is only displayed on models with a USB port. It shows available USB storage space and occupied capacity, for the printer — its name and connection status. By clicking on the name of the panel, you will be redirected to the Applications page.
Applications
This panel provides a list of installed applications (their set depends on the model's capabilities and a selection of components of the built-in operating system of the router).
Switches are available to enable/disable applications quickly.
By clicking on the description, you can quickly go to the configuration page of the corresponding application.
Network ports
Here you can see the port status of the built-in network switch, the speed of the cable connection and duplex mode. If a port is configured in a certain way (for connecting to Provider, IPTV set-top box, Telephony), a special icon will be displayed on this port. By clicking on the name of the panel, you will be redirected to the General System Settings page.
Mesh Wi-Fi System
This section shows information about the statuses of extenders and clients in your Wi-Fi system. By clicking on the section name, you will be redirected to the Mesh Wi-Fi System page.
Wi-Fi Monitor
This section shows the load graph of the radio channel in use. The graph shows the channel utilization for the last 3 minutes. By clicking on the section title, you will be redirected to the Wi-Fi Monitor page for more information.
Traffic Monitor
This section shows a chart of the Top 5 traffic consumers in the last 3 minutes. By clicking on the section title, you will be redirected to the Traffic Monitor page for more information.
About the system
This panel shows information about the router's model, its service tag, the KeeneticOS version, auto-update status, device operating time, current time (synchronized with a time server automatically when connected to the Internet), CPU load, available and occupied memory (RAM).
