Method 1
Connect the Extender to the Main Router using the supplied Ethernet cable. Connect the Extender to the mains via the supplied power adapter. Make sure that the indicator
on the device you are connecting to is illuminated and not blinking.
Open a web browser, go to my.keenetic.net, log in to the Main Router's web interface. Open the Mesh Wi-Fi System page and click Acquire to add the Extender to your Wi-Fi System.
on the Extender will illuminate.
Not
Method 2
For models that do not have a hardware mode selector on their cases, you can change the mode in the web interface. On the General System Settings page, click the Change Operating Mode' button and set the Extender Mode.
On the Extender, push the
(Wi-Fi Control) button once to start a fast WPS connection to the wireless network of the main router.
In the same way, push the
button on the Main Router.
Not
If you use a dual-band Keenetic model Omni DSL (KN-2011) as an Extender, push the Wi-Fi button twice to connect to a 5 GHz wireless network. In the same way, push the button twice on the Main Router. If you push the Wi-Fi Control button once, you'll be connected to a 2.4 GHz Wi-Fi network, but when Extender captured in a Mesh Wi-Fi System, the wireless connection between routers will only work in the 5 GHz band (currently a limitation of the Wi-Fi System design).
Open a web browser, go to my.keenetic.net, log in to the Main Router's web interface. Select the Wi-Fi System section and click Acquire to add the Extender to your Wi-Fi System.
Not
Not
