KeeneticOS component description
KeeneticOS supports the following components:
The information is for version 4.3.1
Languages
English, Dansk, Suomi, Français, Deutsch, Italiano, Polski, Português, Русский, Español, Svenska, Türkçe, Українська | A maximum of three web interface languages can be selected in the system. English is a mandatory component. |
Basic components
Initial Setup Wizard | |
Wi-Fi interface | |
Network accelerator engine | Improves routing performance |
DHCP server | |
IGMP/PPPoE proxy service | The IGMP/PPPoE proxy relays IGMP/PPPoE traffic between network segments |
UPnP service | Allows the NAT and the firewall rules on this device to be configured automatically |
SSH server | |
Wi-Fi system controller | |
WPA Enterprise |
System operating mode
Access point/Extender mode | For creating a new Wi-Fi network or to increase the coverage of an existing one |
Adapter mode | For connection of non-Wi-Fi enabled devices to a wireless network |
Repeater/Extender mode | For expanding the wireless network of another Keenetic |
Internet safety
SafeDNS® | |
NextDNS | |
Cloud-based content filtering and ad blocking |
Network functions
PPPoE client | |
PPTP client | |
L2TP client | |
OpenConnect VPN client | Allows to establish OpenConnect connections from this device |
SSTP VPN client | |
802.1X client | Provides login/password-based authentication support over Ethernet networks. |
KABiNET ISP authorizer | This is the replacement for PC-based utility used by subscribers of the KABiNET ISP |
PPTP VPN server | |
SSTP VPN server | |
L2TP/IPsec VPN server | Allows to connect to home network devices using L2TP/IPsec PSK |
Site-to-site IPsec VPN and L2TP/IPsec VPN client | |
OpenVPN client and server | |
NetFlow Monitor | Gathers information about network traffic forwarded to the Internet and exports flow records to a NetFlow collector |
Application-layer gateway (ALG) for FTP | Provides customized NAT traversal filters to support address and port translation for FTP protocol |
Application-layer gateway (ALG) for PPTP/GRE | Provides customized NAT traversal filters to support address and port translation for PPTP/GRE protocols |
Application-layer gateway (ALG) for RTSP | Provides customized NAT traversal filters to support address and port translation for RTSP protocol |
Application-layer gateway (ALG) for SIP | Provides customized NAT traversal filters to support address and port translation for SIP protocol |
Application-layer gateway (ALG) for H.323 | Provides customized NAT traversal filters to support address and port translation for H.323 protocol |
Application-layer gateway (ALG) for ESP | Provides customized NAT traversal filters to support address translation for the ESP protocol |
IPv6 | |
EoIP VPN tunnelling | |
GRE VPN tunnelling | |
IP-IP VPN tunnelling | |
WireGuard VPN | |
IKEv1/IPsec and IKEv2/IPsec VPN clients | Allows to establish IKEv1/IKEv2 client connections from this device |
Proxy client | Allows the establishment of connections via SOCKS/HTTP proxies from this device |
ZeroTier client | A Smart Ethernet Switch for Earth: Create flat virtual Ethernet networks of almost unlimited size |
OpenConnect VPN server | |
IKEv1/IPsec and IKEv2/IPsec VPN servers | Allows to connect to home network devices using IKEv1 and IKEv2 |
Utilities and services
Service for mobile application | Provides remote management of your Keenetic device via the mobile app for Android and iOS |
Cloud services agent and KeenDNS | The cloud agent provides services for devices to connect to the remote monitoring and management system (RMM) and operate the domain name KeenDNS service |
Internet connection status monitoring (Ping Check) | |
Traffic classification engine | Provides detailed insights into network traffic with application and user-level visibility |
Traffic shaper | |
UDP-to-HTTP proxy (udpxy) | Allows home network devices that do not support multicast traffic to watch IPTV channels |
Dynamic DNS (DDNS) client | |
SNMP server | Allows to remotely gather statistics from this device |
Captive portal | Application for creating a public Wi-Fi zone with SMS authentication |
Packet capture | |
DNS-over-TLS proxy | Provides domain names resolution via secure DNS-over-TLS protocol |
DNS-over-HTTPS proxy | Provides domain names resolution via secure DNS-over-HTTPS protocol |
mDNS service | Allows this device to handle and relay Multicast DNS and DNS-SD messages |
OPKG packages
Open Package support | |
Kernel modules for file system support | Modules: FUSE, CIFS, NFS, UDF, ISO9660 |
Kernel modules for USB Video support | Modules: USB UVC |
Kernel modules for USB Audio support | Modules: USB Audio, USB HID |
Kernel modules for Netfilter | ARP Tables, Ethernet Bridge Tables, IP Tables, IP set |
Kernel modules of the Traffic Control support | Schedulers: SCH_HFSC, SCH_INGRESS, SCH_CODEL, SCH_DSMARK, SCH_HTB, SCH_GRED, SCH_PRIO, SCH_RED, SCH_TBF, SCH_SFQ, SCH_TEQL Classifiers: CLS_ACT, CLS_FLOW, CLS_FW, CLS_ROUTE4, CLS_TCINDEX, CLS_U32, CLS_BASIC Actions: ACT_MIRRED, ACT_SKBEDIT, ACT_POLICE, ACT_IPT Ematches: EMATCH_U32, EMATCH_CMP, EMATCH_NBYTE, EMATCH_META, EMATCH_TEXT |
Kernel modules for USB over IP support | A solution for sharing USB devices over TCP/IP network |
Kernel modules for USB DVB tuners support | Kernel modules for USB DVB tuners support |
Due to the different hardware configurations of Keenetic routers, we do not guarantee that all components and specific combinations of components available for a particular model can be installed at the same time. In addition, some operating system components are mutually exclusive and cannot work simultaneously.
You can get the recommended set of components by installing the KeeneticOS firmware for your device from the Download Center.
