Characteristics of supplied removable LTE antennas
Keenetic Explorer 4G (KN-4910) comes with two removable omnidirectional cellular antennas.
SMA female connectors are used on the housing; the antennas are equipped with an SMA male connector.
The physical dimensions of the complete antennas are shown in the figure (in mm):
Characteristics of the LTE antennas supplied with the package:
Frequency
824 MHz ~ 960 MHz
1.71 GHz ~ 2.17 GHz
2.3 GHz ~ 2.69 GHz
Impedance
50Ω
Standing Wave Ratio (SWR)
≤3.5 Max.
Antenna Gain
824 - 960 MHz: 2 dBi
1710 - 2170 MHz: 3 dBi
2300 - 2690 MHz: 4 dBi
Polarization
Linear
Return Loss
-5 dB Max
Cable Type
RG-178
Connector Type
SMA (Male)
Operating Temperature
-40 ~ 65 ℃
You can use external directional antennas equipped with SMA male connectors (sold separately) if necessary. For more information, see Connecting outdoor directional antennas to Keenetic with built-in 4G/3G modem.
