When you need to expand your Wi-Fi coverage in a large apartment, country house or small office, you can add additional Wi-Fi extenders to your Keenetic Main Router. Connect them over Ethernet for maximum performance or over Mesh Wi-Fi without cabling.
Method 1
  1. Make sure that your Keenetic Main Router is on and is connected to the Internet.
  2. On the Keenetic that you want to make a Mesh Wi-Fi Extender, set the A/B mode switch to position B. The mode switch is on the device's side panel.
    For models that do not have a hardware mode selector on their cases, enable the optional mode in the web interface. On the General System Settings page, click the Change Operating Mode button and set the Extender Mode.
  3. If your Extender has the hardware Operating Mode switch on the case, perform a factory reset (using the Reset button).
  4. Connect the Extender to the Main Router using the supplied Ethernet cable. Connect the Extender to the mains via the supplied power adapter. Make sure that the indicator internet_led.png on the device you are connecting to is illuminated and not blinking.
  5. Open a web browser, go to my.keenetic.net, log in to the Main Router's web interface. Open the Mesh Wi-Fi System page and click Acquire to add the Extender to your Wi-Fi System.
  6. Disconnect the Extender from the Main Router and move it to the location in your home to increase Wi-Fi coverage. If the Extender is successfully connected to the Wi-Fi System, the indicator internet_led.png on the Extender will illuminate.
    The Keenetic Wi-Fi System supports both wireless and wired connections between the Main Router and Extenders for maximum network bandwidth and stability. For information on the components and performance of your Wi-Fi System, see the Wi-Fi System section of your Keenetic web interface.
Method 2
You can do the same by using the Wi-Fi network management button with the WPS Quick Setup mechanism.
  2. On the Keenetic device, you wish to be a Mesh Wi-Fi Extender, set the Operating Mode switch to position B.
    For models that do not have a hardware mode selector on their cases, you can change the mode in the web interface. On the General System Settings page, click the Change Operating Mode' button and set the Extender Mode.
  4. On the Extender, push the wps_button.png (Wi-Fi Control) button once to start a fast WPS connection to the wireless network of the main router.
    In the same way, push the wps_button.png button on the Main Router.
    If you use a dual-band Keenetic model Carrier (KN-1713) as an Extender, push the Wi-Fi button twice to connect to a 5 GHz wireless network. In the same way, push the button twice on the Main Router. If you push the Wi-Fi Control button once, you'll be connected to a 2.4 GHz Wi-Fi network.
    After a successful connection is established, the indicator internet_led.png on the Extender will illuminate.
  5. Open a web browser, go to my.keenetic.net, log in to the Main Router's web interface. Select the Wi-Fi System section and click Acquire to add the Extender to your Wi-Fi System.
  6. Move the Extender to the location in your home to increase Wi-Fi coverage. If the Extender is successfully connected to the Wi-Fi System, the indicator internet_led.png on the Extender will illuminate.
    Keenetic Wi-Fi System supports both wireless and wired connections between the Main Router and Extender for maximum network bandwidth and stability. For information on the components and performance of your Wi-Fi System, see the Wi-Fi System section of your Keenetic web interface.
    If there is no Wi-Fi System menu section in the settings of the Main Router, in this case, a special component Wi-Fi System controller must be installed. You can do this on the General System Settings page in the KeeneticOS Update and Component Options section by clicking on Component options.
